2000 3.9 Dakota
I bought the summit 15 gallon satin aluminum fuel cell. Does anyone have any reccomendations for an inline fuel pump? My biggest problem is what to do about the sending unit. Dodge has the most messed up ohm load on the factory unit. Am i forced to run an aftermarket guage? Any info would be great!
my boy is makeing me a setup so i use the stock unit pump and guage in a fuel cell . the fucked up thing a bout 97 and up kota thay have no return line it blead off in the tank so a in line pump WILL NOT WORK. but i saw a set up on krc perfoemance.com that might be of some help if u use that inline pump
Well if you run an inline pump with a pressure regulator it will have a return line off the regulator. I wound up buying a Mallory 100 psi pump with the mallory regulator. I'm just going to run stainless braided fuel line for the whole truck.
