SO I BLEW AND SO I FIXED THAT. AND KNOW WHEN I START OFF IN THE MORNING THE IT STARTS NICE, I LET IT WARM UP AND THEN WHEN I LEAVE I GET A BLOCK AWAY AND IT LOSES POWER AND STARTS IDLING LIKE ITS CAMMED OUT. AND WHEN YOU TRY TO TAKE OFF BEARLY AND THROTTLE AND THEN NOTHING AND POPS LIKE 4 TO 5 TIMES THEN ALL THE POWER ID RESTORED AND ITS LIKE A NEW TRUCK RUNNS STRONG WITH OUT ANY MORE PROBLEM.
I HAVE REPLACED EVERY SENSOR BUT THE CRANK POSITION SENSOR AND THE INJECTORS.
AND I EVEN REPLACED THE FUEL FILTER.
SO BEFORE I BURN THIS TRUCK TO THE GROUND WHAT THE HELL COULD IT BE ?? :confused:
i have already done plugs wires cap & rotor when i did the head gasket. i will have to check the wires and then replace the crank position sensor.
thanks
again sorry for the caps lock (habit with work)
· Gen2 help hotline
first put a scan tool on it and see if the CPS is faulting out..also when u did the heads did u check your lower intake plenum gasket? this is know to fail and cause a hell-acious vacuum leak/misfire/sputter
also was the base timing set right when everything was reassembled? if not then your CPS will have no idea where to start advance timing during driving
