For all you 2000 4.7 owners,
Here is a guy's experience with the flash:
"The Leach Flash advances the total ignition timing from whatever you currently have up to 29 degrees at wide open throttle. My total timing before the flash was a lazy 17 degrees. Once I got mine flashed, I picked up a solid 4 tenths at the dragstrip. I also picked up 1.5 miles per gallon on the highway. Once I get done at the strip, I can get 22 mpg on the way home doing 60 mph.
My speed limiter has been set to 220 miles per hour and the rev limiter is at 6800 rpm. I have only bumped the rev limiter once coming out of the burnout box in 2nd gear. Mine is a manual trans, so I set my own shift points.
My current best time at the strip is a 14.14 @ 94.79 mph. You can read more about stuff here:
http://www.dragtruk.com/ENTRIES/0F64H9L1P5IL.html "
Here is his email for those that might have some questions:
[email protected]
[email protected]
