Yea you will get a 3/5 drop with that stuff. If you or any of your buddies have any fabrication experience then you can build yourself a small c notch for peanuts. Go to you local steel supply and dig through their remnant piles and find a peice of pipe or tubing that's 5" or so diameter with a wall thickness of 1/4" and about 6" in length. Then find some plate to plate the inside of your frame rails.Will that affect the carry load in anyway? I use it to carry trans & motors a lot
have it sit like this guys.
He says its a 3/5 drop on 255/35/20.
I'm really new to this.
Example, lets say I buy:
Front
3″ lowering control arms from DJM
Rear
3" lowering leaf springs from Belltech
2" lowering steal blocks from DJM
Will those combined get me a 3/5 drop?
Then I just use the same specs of wheels he has to achieve the same stance?
I have an 01 same body style and I had to cut out the front bump stops I got like 1.5 inches frome tire to fender. I'm running 20x9.5 with 265.50s in the front and 295 45 in the rearJust wondering what the lowest somebody has gone in a 3rd gen being static & with what setup in specs. Like wheel size & etc.
I can't find a forum post so I'm asking this.
