I'm not really familiar but im interested in buying bags for my truck and i found a site that sells it for my truck for 1600, just wanted to make sure is this all i need to have, bottom is details of the package. plus how much it usual cost to install it.
1 - Viair 450C Chrome Compressor
1 - Pressure Switch 110-145PSI
1 - Air Lift 5 Gallon, 8-Port Tank
4 - Air Lift 3/8" Chrome 300PSI Electric Valve
1 - Dual Electric Gauge Panel with one 200PSI Gauge
2 - Fuse Holders with Cover
3 - 15 AMP Spade Fuse
3 - 30 AMP Spade Fuse
1 - 40 AMP Heavy Duty Relay
1 - Single Relay Socket
50ft of 1/2" DOT Synflex Air Line
50ft of 1/4" DOT Synflex Air Line
1 - Thread Sealant Packet
1 - Air Line Cutter
1 - 1/2" Street Tee Fitting
2 - 1/2" NPT to 1/4" FEM Bushing Fitting
2 - 1/2" NPT to 1/8" Bushing Fitting
1 - Drain Cock Fitting
1 - Inflation Valve Fitting
3 - 1/2" NPT Hex Plug
2 - 1/2" NPT to 3/8" FEM Bushing Fitting
2 - 3/8" Street Tee Fitting
4 - 3/8" NPT to 3/8" NPT Straight Fitting
2 - 3/8" NPT to 1/2" Line Elbow Fitting
2 - 1/2" Line Tee Fitting
2 - 1/4" NPT to 1/2" Line to 1/2" Line Tee Fitting
2 - 1/4" FEM to 1/4" Line Straight Fitting
Check out the air kit upgrades section at the left for upgrades and additional items.
Chevy Avalanche - Front (2000-2005)
Includes bags & brackets for both left and right sides.
Chevy Avalanche - Rear (2000-2005)
Manufacturer: KMW Performance
i dont know how low you are wanting to go i dont see ne thing missing i believe that should be all you need to get it down
Yeah, that sounds about right. And if you want more "play time" or recovery time, get another 450 Viair to pump up the tank. One of my boys has a blue avalanche on 24"s bagged. If you want I will get some info from him to help you out, cuz its the same truck, obviously. But that sounds about right. Where do u live? I'm here in memphis, tn. The guy with the bagged avalanche has this shop with my friends, and the bag trucks all day. Just get at me if u need that info.
