1 - 4 of 4 Posts
Just picked up my first Dakota its a 92 single cab short bed 4x4 with 318. I wanna level it and then maybe go 2 inch body lift just to fit bigger tires. I currently have 30/9.50R15's on it but they rub when i turn. I wanna go 31/11.50R15. So could anyone point be in the right direction for a leveling kit and a body lift, And would that be a good way top go?:1237:
CHEV-OTA
I would go with the body lift its easier but the lift makes more frame clearence from the ground but you could go with both of these or ethier one.
Just crank the front torsion bars if you want to make it level in the front.
What can I fit on my 4x4 Dakota?
Stock...29 -30 inches
1-2 inches... 31s
2-4 inches... 33s
4-5 inches... 35s
Check http://www.4wheeloffroad.com/techart...ide/index.html
Copied from dodgeforum.com
Heres a 2 inch lift kit.
1991-1996 DODGE DAKOTA 2" LIFT KIT B LEVELING 4x4 | eBay
And heres a 2 inch body lift.
#642X. 86-96 Dodge Dakota 4WD 2 inch Body Lift Kit (685885000088) | eBay
Hope it helps
Stay away from body lifts. they are cheap and easy, but they don't do much for you. trim fenders and stick with some suspension lift stuff that will increase clearance, flexibility, and suspension performance.
A combo of a leveling kit, 2 inch suspension and maybe a 2 inch body would give me the look im going for. i have 30/9.5R15's on there now and am gonna put 31/11.50r15's on it so the leveling kit and 2 inch suspension should do the job. thanks for the links.
1 - 4 of 4 Posts
