i accidently put this in another section, so here goes, does anyone know of any cheap mods/easy tweaks to make to an engine to make it better, i don't have much money, so i doubt there's much, but i hope there's something. I've also heard that taking the top off the air filter, and putting it on backwards essentially makes it a cold air intake, is that true?
If you have any skills with a dremel tool you can shave the fins on your TB like this one.....(the one on the left) lol
If you have a V6 and If you don't have the confidence to try this you can spend a little money and get a V8 TB...you may need to get a V8 TB cable too but you should be able to get both for under 100 bucks
what does shaveing the fins do????Also to go along with what he said use a dremal to bore out the little hump in the middle of the throttle body inlet shaft.I did and it help the shift points and give it a lil more go off the line.
