New to the site I am looking for info on installation of R/T wheels 17 x 9 they make contact with my upper control arms when the wheel is turned I see many with these wheels on them.. I will lower it through the winter but can I install with out lowering?? Thanks Steve
Just for clarification, your truck is what year? Assuming its not a first gen *87-91* but a six bolt 94 or newer? Likely has to do with the offset, and you'll probably need to run a small spacer to clear at full lock. However, if your going to lower it down the line, a 17x9 factory R/T wheel likely isn't for you. You'll need to narrow your track with with a narrower axle, and custom control arms up front.
