ok i bought a 96 dakota slt clubcab. great condition except for one thing
who ever had it cut the factory wiring harness for radio.
but my question is will a radio out of a gen 3 dakota work in the truck?
the reason i ask is i have a factory radio laying around and i picked up a wiring harness out of a gen 3 dakota so i could have the plugs.
but is the wiring of the 96 diffferant than the wiring of a 2000 dakota?
its not a bose system or nuthing fancy just plain ol tape deck. just want a radio to listen too. any help would be appreciated.
There should be a constant, a power a ground and all your speaker wires.
You could strip your wires down on your 96 and the wires on your gen 3 harness and due the process of elimination. Once you find power and ground fade the radio to the front left, front right, you get the idea. Just an idea if you cant get a hold of a wiring diagram. It can be wired wether the wire colors are the same or not. i not sure how the physical fit will be. Good luck
1995-96 Dodge Dakota Stereo Information
Constant 12V+ Red/Blue
Switched 12V+ Red/White
Ground n/a
Illumination Black/Yellow
Dimmer Orange
Antenna Right Front
Front Speakers 5 1/4" Doors
Left Front (+) Dark Green
Left Front (-) Blue/Orange
Right Front (+) Purple/White
Right Front (-) Brown/Blue
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Red
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
1997 Dodge Dakota Stereo Information
Ground n/a
Dimmer Orange
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Green
Left Front (-) Brown/Red
Right Front (-) Dark Blue/Red
Rear Speakers 5 1/4" Rear Corners
Left Rear (-) Brown/Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
hope this helps. check out alldatadiy.com or the12volt.com
