1 - 1 of 1 Posts
I recently resprung my 2000 Dakota R/T extended cab, The ride
was way too rough, got tired of it, so I researched
Spring Dimensions.
OEM
Moog 80866 @ 844 lbs/inch,
Replaced them with:
Moog 586 @ 433 lbs/inch,
Yes the springs are longer, they have to be to support the same weight.
Also installed new rubber isolators, cut one turn off bottom of spring,
ground a small flat on upper springs to prevent rubber punch through,
ride height is approx. same clearance in fenders front and back.
1 - 1 of 1 Posts
