1 - 8 of 8 Posts
i scored a sunpro tachometer for free... anyways how do i hook it up???i know one wire has to go to the distributor and one to the battery? i think newayz... can anyone help?
red wire=battery black=ground green=negative coil wire and white= lights
so i run a wire straight to my battery???
o and which wire is the neagative coil wire??? i tried to h ook up a msd ignition box and i couldnt figure out which one was pos. and which one was neg.
anyone??? i was told the green and orange was the negative coil wire... is it?
go to msds website...they have instructions for the box install and it tells you which wires to use....I put in a 6AL box, and i think the green and orange is the positive...And You can just run the red power wire to the fuse box or to a power wire under the dash somewhere...Go get a test light and find you a hot spot to tie into
well, im trading the box for a set of toxic drop shox and some 6 1/2 memphis door speakers... but would it be ok if i took the green wire and ran it thru the firewall straight to the coil wire, then run the red wire to say my cd player hot wire??? what would i hook the white wire to so the light comes on?
1 - 8 of 8 Posts
