I have a paxton sn-93 for sale. I had it on my v6 dakota. The unit needs a rebulid, but other then that the system is fine. It is a full system which includes: fuel system upgrade with the paxtamap fueler, fuel pump, fuel regulater, ignition system with boost retard (I cut the wire that makes it fire for a v6 so if you are going to put it on a v8 you need to resoldier that wire), and oil cooling system with oil pump and an oil cooler. The unit is fully polished with a polished air cap. It makes 8lbs of boost. Paxtons novi system sells for over $5000.00. This unit with the cost of the rebulid will be WAY less then that. Save money!
$950.00!
$950.00!
