I'll try it out, but if I don't post tomorrow !finger j/k.KaoticDakota said:you only need to switch one wire....the power on the side marker and the turn signal wire on the turn signal...i believe
no they didn't work out at all. Te wiring was completely different from my Dakota's. I'm going to talk to my cousin a little more to see if he knows about using relays.btyking said:Okay, definitely not being a 'post whore'. Just wondering about the Acura lights and if they worked out...didn't really look at the date on it.
Bk
damn that's a lot of shit to go through... I'm good though. Just gotta get finished with my bags and I'm set.autohauskust said:yo the most you can do with that is take the hot wire off the 194 bulb thats constant and the cut power for the blinker hot from both of the 3157 conectors that will make it so that you have the 194 only blink and the 3157 will only stay constant the only down fall is the blinker will blink fast but alll you have to do with that is go to radio shack and get some resistors and put them in line with the 194 hot you just created from the 3157 its pretty easy should take no longer than an hour i did it to mine but i kept gettin pulled over for not usin my blinker cuz its not too bright
