Is the center section of a 93 rearend cast? I don't have the truck available to check. Just wondering about welding to the pumpkin. Thanks
im prett sure it is....you can weld to cast as long as you turn up the heat.....but your supposed to use different wire...im sure a local welding supply store would be able to get you the wire you need......
