I need help with this "should be easy" problem
I put 1998 dakota wheels on my 93 dakota. 4.5 x 6 bolt pattern. In sharp turns the upper control arm comes in contact with the wheel. I bought 10mm (1/2 inch) spacers to use with the wheel lugs now being too short. The stock wheel studs are 568 knurl/ 1/2 x 20 that are 1 23/32 inch long.
Easy to fix - longer wheel studs I think. I decide 2.09 (1/2 inch) longer wheel studs would handle but nooooooooo. Jegs and Summit closest appear to be 2.875 long which I believe would be to long for the lug nuts to fit right.
Any ideas???????????. :confused: :confused:
